FZ1riderNY
I got home from work today and decided to swap out the front sprocket instead of waiting for tomorrow. I want to get everything done so I can just go and enjoy the ride. I'm changing out the new JT Front 16T with the Yamaha OEM 16T. The "all steel" JT was just a bit too noisy for my tastes.
I started by removing the sprocket cover, rear set, and frame cover.
This is the JT Sprocket ready for removal.
I had Richie hold the rear tire while I removed the nut with the air gun.
The nut came off without applying any heat thank God!
Next I loosened the rear wheel and moved the set screws all the way in to give full slack in the chain.
Next I loosened the rear brake caliper bracket bolts front and back.
With the wheel loose, just a couple of hits forward and the chain was off.
The front sprocket now comes off easily.
Here are the two sprockets side by side. The OEM on the right has a rubber cushion which helps relieve some noise while rolling.
The new sprocket now goes in place.
Brand new washer goes in next.
Followed by the nut.
Once thats done, the rear wheel goes back on before tightening anything on the front sprocket.
I took a break to say hello to my new neighbors. They've been hanging around the garage for the last two weeks. They are quite playful and keep me entertained while I worked.
Once the chain slack was adjusted, and the rear wheel locked down, I had Richie step on the rear brake while I torqued down the front nut. The manual says 51ft lbs but I went a tad bit more as I do on the rear axle nut. Next I bent the tab down on the locking washer. One side perfectly flat and I bent the other tab down as well.
All finished. Just reinstall the cover plate, rear set, and frame cover. Connect the gear shift linkage rod and your all set. I cleaned everything up and took her for a quick spin. Not a peep out of this baby! I'm happy again. Tomorrow the lower fairings go on for good and I'm gonna start riding the heck out of her!
So now I have a JT 16T Sprocket (All Steel) that has less than 300 miles on it. I'd call that almost new. If anyone wants it just pay me for the shipping and handling and it's yours. First dibbs gets it. Just post it here.
