runningman
So I took apart both of my front stanchions this weekend. It took a while but I got the seals changed (which were leaking), replaced the old oil and got them buttoned back up. Upon inspection today, my stanchion which handles rebound is working great. I can test it off of the bike and see that when I use the adjustment screw, it very obviously changes the rebound rate. However, the same can not be said for my compression side.
When I tested my compression stanchion, it didn't adjust at all when using the adjustment screw. When using it next to my rebound fork, it seemed as if it was stuck on full soft. When putting the fork together, I set the top cap lock nut at 12 mm from the top of the damping mechanism. I also ensured that the damper rod adjustment screw was set in 13 mm from flush on the bottom of the top cap. However, when I go to put my top cap on, a few millimeters from hitting the lock nut, it won't go on any more. Even gripping the damping mechanism and using a wrench to try and get the top cap to go on will not allow it to reach the lock nut stationed at 12mm.
I'm pretty sure that for whatever reason, my compression stanchion is at full soft and stuck there. What are things that I can check for when putting this together? My damper rod and damping mechanism don't seem to be damaged at all. The damping rod (thin rod inside of the damping mechanism) does feel not extremely well lubricated, though. It feels like during it's first 0.5 mm of travel it takes a little bit more effort than it probably should when it's sticking out of the damper . If you're willing to help, and can't visualize the issue, let me know and I'll try to grab pictures and post the proper visuals from the service manual.
