bruceridesthestryker
i had my rotor fail on my 2007 fz1 so i pulled the cover and removed the rotor and stator. i discovered that the spacer with the oring and thrust washer were missing. i got my magnet and fished out the washer but the spacer is hiding. is there an easy way to get it out? can i pull the bottom pan off without dropping the motor? my yamaha service manual does not give me that info. it might be better to pull the pan and clean the oil pump screen out it wiped out the magnets really bad. any help is appreciated thanks bruce
