Chain noise
Hi
Any one find their drive chain noisey ?
Just replaced mine with sprockets and I think it seems to whine more than before ,, only explanation I can think of would be due to the amount of crud I removed from inside the front casing acting as a sound barrier..
Any other noisey chains out there.
Seasons greetings to you all
Hi
If you used an aftermarket front sprocket then this would account for the extra noise, as the stock front sprocket has rubber noise dampeners on it.
No chain noise here [emoji5]
No noise from the valves either. After I started using ear plugs, that is [emoji14]
Sendt fra min EVA-L09 med Tapatalk
