battleshaft
Hello all,
I've read a few threads with a similar theme to this, but none seem to specify the root of the problem.
My bike is a 2008 FZ1N - 8000 miles, never dropped/damaged. It tracks/pulls to the left when weight is off the bars. It requires a slight push of the right handlebar to keep it riding straight.
Tyre pressures are fine, nothing appears bent, headrace bearings are fine, wheel bearings are fine, wheel alignment is good....and it's not the camber of the road (tested on multiple surfaces at various speeds to make sure.
A local garage suggested maybe loosening all bolts on the front end while supporting the bike with a jack in case something is slightly misaligned, i.e. a twisted fork leg.
I'd greatly appreciate any more suggestions/thoughts on what could be causing this and would be interested to hear if anyone on here has had a similar problem.
Cheers!
Cheers!
