2001 FZ1 questions
MagnaFZ1
Hi I just bought a 2001 FZ1. I have noticed a few strange things. WHen in Neutral the green indicator light will go out when you rev the bike up and then come back on when the bikes at idle. Also the fan will come on when sitting in neutral but when you put it in gear it shuts off.
Any help is appreciated.
Thanks
dmsantam
I can't help with the neutral indicator light. However the fan going on while idling in neutral is normal. It operates on a timer. As you noted, it switches off as soon as you pop it into gear. Nothing to worry about there.
MagnaFZ1
OK I found a fuel leak in the carbs. Is there a common problem that I should know about? I also may have oil leak on the *drivers side maybe the stator cover? Any common problems for the FZ1?
Thx
