mgosset1
Dang I got 9 tons of a/c running over here in Dallas, Tx.....glad to hear someone is getting cool weather....
Fitted bar end mirrors today, Il let you know how i get on with them..
Had to loose the standard chrome ones as they just look so wrong lol
how did you do the right side, throttle side* mirror??? I gave up and just did this.
WHUT? I guess you get a great view of your neck with that setup? I mean really WTF? What can you SEE in those mirrors with them mounted there? Maybe this is a joke? :retard:
\nope, though you can't see directly behind you. you can see whats in the left and right lane behind you and anything 50+ Ft directly behind you, the view is underneath the arms.
loosten the brake lever bracket, switch gear and throttle assembly and slide them up the barsa little .
Put the mirror on the end then the bar end weight then you can pull the mirror to where the weight starts, move everything back making sure your throttle doesnt rub on the mirror ( Leave a couple of mm). clamp everything back down.
You have to cut the grip and the throttle tube back about a 1/4 inch and then it fits like a glove without the throttle sticking. :Rockon:
there are notches that prevent the movement of the parts you mention and I really don't want to cut anything....I don't know how permanently I want to attach the mirrors.
Thats what I was afraid you would say, Im trying not to cut anything.... but you never know.
Where did you get the lock ? And how did you change the key, COOL STUFF.
YAMAHA : HelmetHangerSet [Q5KYSK056E03]Somebody in the helmet lock thread came up with the part number from a Japan site. Cost about $60 for the lock, bracket and screws.
As for the key, I swapped the gold wafers around so it would work with the ignition key ( left 2 out)
