OneSizeFitsAll
That's good news. Cool little unit! Looks even better under my new Sargent seat
I'm still about 1-2 mph off. Do I correct once more or do I live with the difference and forgo the correction and accept it as my safety valve? I was considering -11.1% as my final. but then I'd have to readjust if I put on Pilot Road 2 tires. Thoughts?
Hey Everyone,
Well NJFZ1 gave me some good advice about 16/47T sprocket setup and now I have 3 questions about the SpeedoDRD.
#1. Where is the speedometer input on a 2006 FZ1?
#2. On the SpeedoDRD, will the wires be long enough to put it under the seat so it can be reprogrammed later if necessary? Any other suggestions?
#3. I have read stuff about how your speed and mileage on the bike may not necessarily be integrated. In other words, even if my speedometer is corrected, my odometer could still be off a good bit. If the odometer isn't correct, there is no reliable way to even check gas mileage unless you ride with a GPS.
Thanks in advance for any help you can offer!
I have to dredge up this old thread and call out the SpeedoDRD crowd to ask questions.
Are any of you having any trouble with this unit? I ask because without it, the bike runs very well. After plugging it back in (with dielectric greased fittings) at about 3k to 3800k RPMS the bike feels like it is studdering. The RPMs don't seem to fluctuate much but the whole bike feels like you are on a steady throttle and then applying the brake for 1/2 to 1 second intervals? VERY jerky! So, unplugged it and the bike is back to smooth.
So far, the only reference I found on Google was that some settings just don't sync well with the ECU so it was suggested to try a new setting. Most have said to stay away from any setting that had .0 in it. I'll have to wait for a sunny day and then I'm going to route the board out from under the seat so I can set it without removing anything and do some trial runs at various settings. If I find a setting that works with the correction and doesn't give this odd behavior, I'll leave it alone. Otherwise, I'm removing it and sending it to 12 O'Clock Labs to diagnose it and ask for help resolving this. I've sent them a support request explaining the issue and will let you know what they say. As far as I know, they stand behind their product.
Anyone else have an issue? Can a few of you change your settings? Round up or down to the next .0 or .5 setting and test a steady 3300 RPM throttle? Let me know what you find. Also, can you please note the version of the unit? It's either on a sticker under the board or printed on the board itself.
Any ECU flashings that can be done at the dealer? Maybe this is a TSB.
Unrelated....if this thing corrects for gearing..you could technically make it record much less than the bike went correct? Surprised this unit is legal!
Off topic... where do you ride here in NH? Wife and I are all over the state during riding season. Maybe meet up for a ride...
