- Admin
- #1
FZ1inTX
Adminstrator
Some time ago, I purchased Tony's sport scoops from him. He's been in the crash with David's Dad and one was scratched deeply. I fixed the damage and intended to paint them to match the Cobalt Blue bike BUT after adding the stuff to the cart at Color Rite for the aerosol kit? $150??? Crap! I can buy new color matched ones for $250 and sell these ones ready to paint!!! So, I chose to go satin black to best match the frame. This ties them into the frame and engine rather than appearing as a fairing extension and I have to say I really like it a lot!
Thankfully with the garage insulated, it did not take long to warm it up 70 degrees in there with my 18k BTU electric heater.
I had a moment of Billy luck though... First stand-off to screw into the radiator was almost all the way in and the stud snapped off! I got lucky though... I drilled a small hole in the center of the stud that was now stuck in the radiator mount. I didn't have an easy out so I took a standard allen that was a tiny bit too big and tapped it into the hole with a hammer gently. The stud backed right out! :yes:
Then I had to take the stand-off and cut the nub off that was the stud. I filed it flat and center punched it. Went to the hardware store and grabbed a #9 bit (almost 5mm), a 6mm x 1.0 tap and a small 6mm threaded rod. After a successful tap, cut and placement, I'm back in business.
The frame plates were, in fact, stuck on with double sided tape AND the plastic rivets. I got those off and salvaged the rivets. Thus, here are the results. If the weather lets up, I can take it outside and get better pics!
The extracted stud....
The drilled stand-off...
Tapped and new stud ready!
Right side done.
Left side done.
Right side done.
Left side done.
