Leesykes
I’ve come to start the bike up today and it’s failed. I turned the ignition on and there was power to the speedo screen and to all the lights. The engine turns over but doesn’t fire up.
I have noticed the fuel pump doesn’t prime and there’s no spark.
I have checked the ignition and immobiliser antenna wires for continuity and all checks out ok.
I found there was no permanent 12v feed to the immobiliser (red/green wire). I checked all the other wires and all is ok. So I decided to connect a 12v supply to the red/green immobiliser wire and the bike works.
My problem is I can’t find a fuse in the wiring loom, it’s shown as fuse 4 on the wiring diagram also called safeguard fuse. It’s the fuse that feeds the red/green immobiliser wire.
Can anyone help me find the location of it?
Diagram of fuse mentioned below:
Thanks,
Thanks,
