Rx_FZ1
All the items are off a 2006 fz1 with 14k. All parts are in excellent condition. From a parted out motor due to a broken shift rod. All items are OBO and ships free! They are listed on ebay as well, with pictures. I can PM/text pictures to forum members if you would like to avoid eBay, I know I would. Thanks
Starter Starting Motor - $45.00
Oil/Water pump - $45.00
Crankshaft - $165.00
Oil cooler - $25.00
Clutch basket plate assembly - $100.00
Engine Case - $130.00
Cylinder head assembly valves cover - $130.00 SOLD
Pistons & connecting rods - 75.00
Oil pump cover Right side engine - $20.00
Clutch cover w/Arm Left side engine - $75.00
Magneto flywheel magnet - $175.00
Stator with cover - $65.00
Stator drive gears - $25.00
Countershaft Trany - $55.00
Oil level sensor - $13.00
Ignition pickup sensor - $13.00
Camshaft position sensor - $13.00
Cylinder block - $70.00
Oil Pan - $70.00
Cam shafts - $70.00
Cam chain tensioner - $20.00
Oil cooler - $25.00
Oil Pan - $70.00
Cam shafts - $70.00
