EISTO
My Gen II tends to wear the sprockets unevenly; the front sprocket gets worn on the side facing the engine but not on the opposite side. Now, I know this is textbook evidence of misaligned sprockets. The question is what type of misalignment and what is causing it. I've thought of 3 options so far:
A) Rear and front sprocket are parallel but slightly offset, i.e. rear sprocket further left compared to the front sprocket
B) Rear wheel is twisted at an angle (counter-clockwise)
C) Rear and front sprocket are offset, i.e. rear sprocket further left AND rear wheel is twisted at an angle (clockwise)
However; no amount of adjustment or fiddling has even remotely solved the problem. I'm using calipers to align the rear wheel when adjusting the chain tension, and both the garages I've been to say the adjustment looks good. The last one I visited used a laser tool to check if the chain line was straight.
I've ben through 2 chain & sprocket sets. The garage replaced my swingarm bearings (these were damaged and thought to cause the issue) and the chain/sprocket set was replaced again (3rd set). This week I discovered that it's starting to wear in the exact same manner. The guy at the garage now says he's run out of ideas since it's difficult to obtain a precise measurement of the misalignment.
I've attached pictures showing each side of the front sprocket (the 2nd chain/sprocket set....). As you can see, it's worn on the inside, but the outside hardly has a scratch. This one has seen about 3000 km.
The chain is only worn on the lower inside of the plates that are facing the engine. This is where it's rubbing against the front sprocket (see picture).
Anyone in here with input or similar experience?
