Completely Dead! Please help!
Hi all,
I installed a Yoshi Fender Eliminator kit and everything was working fine - all the lights came on and engine was running. Then I shut it off and did some cleanup including putting the seats back on and now it wont even turn on. Battery is fine, the main fuse (on top of battery) is not blown.
Any suggestions/help would be much appreciated.
Thank you in advance!
You may have a blown ignition fuse. Check the fuse box under the seat, if memory serves me well, it's the 2nd fuse.
Recheck your wiring to make sure you hooked everything up correctly and that there are no shorts.
