jskf16
www.fazerclub.gr
The examination in utmost Spark plugs can say to you if your machine has a problem that needs correction. They portray the attribution of well coordinated machine or badly maintained. The bad plugs can cause the overheat, the hard run, the loss of force and even the failure of machines. Check your plugs Spark plugs regularly and use this diagram as driver in the attribution of points of problems.
1. Normal
2. Regular with the red coating
Cause: Red coating of as resulting from fuels additional substance in unleaded fuels.
3. Fuels that are soiled
Cause: Defectively obstruction-excessive rich fuels problems of ignition of mixes or heat of plugs line too much cold.
4.Detonation
Αιτία:fuels with few octanes
1. Normal
4.Detonation
