The Drone
Hello I’m looking for Satans666 bracket to swap my stock rear shock in to R1
Actually I haven’t ordered tha shock thanks for the suggestionDo you already have the shock? If not, get a later year R1 shock 2015+ and no bracket needed.
Actually I haven’t ordered the shock thanks for the suggestion
Thanks for the info I’ll order a newer modelDo you already have the shock? If not, get a later year R1 shock 2015+ and no bracket needed.
Hi I have just bought a R1 shock 2020 will it fit straight on?Do you already have the shock? If not, get a later year R1 shock 2015+ and no bracket needed.
Thanks for info. I llook forward to put it on, i hope to do it before winter.a little bit of work but nothing most peo
What is better with 04-06 dog bone linkage?Get a 2015 R1 Shock and 04 / 06 R1 Dog Bone Linkage, Put regulator on upper side of its mounting plate, a little bit of work but nothing most people can do. Exup servo eliminator needed.
Thank you!The 2015 R1 Shock is adjustable for ride height ( Length ) and is 315mm long but the standard FZ1 Shock is 320mm Long, so the R1 shock is 5mm short. to make up the difference the R1 shock is just about on its limit for ride height adjustment. By using the 04/06 R1 dog bone linkage which will lift the rear of the FZ1 about 30mm then adjust back down so the rear of the FZ1 is approx 15 to 20mm higher at the back end to make the bike stear nice and quick.
