MEAN 1
Wizard
heres the 06-08 FZ1 spec's -
Engine/Ignition/Transmission
Type Liquid-cooled, 4-stroke, DOHC, 5-valve, in-line four
Displacement - (cc) 998
Bore Stroke - (mm) 77.0 x 53.6
Compression 11.5:1
Lubrication Wet sump
Fuel Management Electronic fuel injection
Ignition TCI
Starter Electric
Fueltank - (L) 18
Transmission 6-speed
Final Transmission Chain drive
Chassis
Length - (mm) 2140
Width - (mm) 770
Height - (mm) 1060
Seat Height - (mm) 815
Wheelbase - (mm) 1460
Clearance - (mm) 135
Dry Weight - (kg) 194
Front End
Suspension Front Telescopic fork
Tyres Front 120/70 ZR17MC (58W)
Brakes Front Dual disc
Rear End
Suspension Rear Monocross
Tyres Rear 190/50 ZR17MC (73W)
Brakes Rear Single disc
Compression 11.5:1
Ignition TCI
Starter Electric
Fueltank - (L) 18
Chassis
Length - (mm) 2140
Width - (mm) 770
Height - (mm) 1060
Front End
Rear End
